Thunderbird email
Thunderbird email
Has any other user of Thunderbird had any problems with when including web links or email addresses in the text of a mail, that they arrive to the recipient broken and won't link?
I've noticed afterwards in my outbox copy that a link may be blue underlined for maybe only half or less of the length of the web link or address although the link is actually correctly typed.
Fixes: 4
Re: Thunderbird email
No, but I'm still using version 11.0.1.
What version are you having a problem with ?
17.0.8
I'm also using version 17.0.8
Just sent myself an email containing a number of URLs and they all appear fine.
Razer
Not that I'm aware of.
Its very intermittent, maybe once in a dozen or so added links.Oddly it seems Ok when typing, but when I check the outbox my copy will appear broken as well.
Fixes: 58
17.0.8 and no link problems.
Customer and Forum Moderator.
