This made me larf !
Fixes: 16
This made me larf !
I have some "white noise" on my phone line, when I listen to the dial tone, using the "monitor" facility.... it is quite loud, however, being hard of hearing, I can only just detect it, when I use the normal earpiece, ( yes pierre I know I can switch my hearing aid to the T position).... without my hearing aid, as this is the only way I can use the phone...
so, I decided to call BT faults (my phone supplier)....
Having dialled 150, and listened to the menu,  "if the number your are speaking from is this number ..... press 1....
Thank you ,..... you now have 4 choices....
(listed the 4 choices and I made my choice)...
to check that we are dealing with your phone I need to check your number..... you said.... 02392 XXXXXXX... if this is correct press 1
you now have 4 choices... (i think).... one of which was
"If you cannot make or receive calls......... press 1 ".......
erm.? ? ?  Roll eyes
ROFL and put the phone down !
Fixes: 58
Re: This made me larf !
The last time I used the BT menu system I finished up back where I started and hung up. Roll eyes
Customer and Forum Moderator.
pierre_pierre
I might be an old Git but aint deaf, jusy wear glasses
Fixes: 16
Cool
need to clean them then......T is next to the Y on the keyboard.... (ok, so they do look quite similar, if you are short sighted !)  Roll eyes
pierre_pierre
forgot to say I am having Carpel tunnel problems, Had the op, but somethings gone wrong, EMM test says the condition is worse, no feeling in thumb and 1st, 2nd fingers on right hand, Seing another "Expert" on 22nd
overdoing it with the mouse, pierre?
pierre_pierre
More like my wood turning, not been able to do any since I think August
thejudge
That's like the famous boot-up message:
"Keyboard error. Press F1 to continue."
a bit like being asked by tyro "Where is the ANY key?Huh
pierre_pierre
got one on SWMBO laptop
Fixes: 16
Crikey me, Pierre. !... how big are the keys on your wife`s laptop ? ?  or conversely..... how BIG is her laptop  ? to have keys THAT chunky..... Roll eyes
pierre_pierre
Sorry, normal size, was using the Macro lens though
for the hun heducated ones http://www.ephotozine.com/article/macro-photography-119
Fixes: 16
Sorry, Pierre,..... I know a "normal" desktop keyboard , when I see an "edited" pic like yours !....  Roll eyes
pierre_pierre
glad you do I have several different layout here, didnt think there was an absolute standard
pierre_pierre
here are some of them, the pink one is a rollup USB for the smaller 7" net book when on holiday
