This Fibre can do 224Gbps
goldenfibre
Fixes: 6
Fixes: 10
Re: This Fibre can do 224Gbps
You posted this in the help and support section of the forum - just what help and support are you seeking?
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
nanotm
this is great so long as you don't have any other light in the same spectrum to saturate the connection(s)
this might work in a subterranean setting but anywhere that gets natural light will find this problematic /
