The planet can be saved
Gordon Brown has told us we have 50 days to save the planet...is that before or after Christmas?
Fixes: 384
Re: The planet can be saved
I believe it's taken from the same report about weapons of mass destruction in Iraq...
My Broadband Ping - PN-Fibre
One of the doom-mongers favorite arguments is the navigation through the ice of of the North West Passage, which is possible now...shussh! don't shout it around but, it has been navigable since 1903-6 and routinely since 1934.
Fixes: 384
and global temperatures haven't increased in 11 years.
but that's not the point.
Fixes: 188
and they are now talking about Global Cooling Roll eyes
Customer and Forum Moderator. Windows 10 Firefox 64.0 (64-bit)
Fixes: 62
Temperature data from UAH
Quote from: Petlew
Ermm....  it's the North EAST passage that's just becoming navigable actually, over the top to the Northern coast of Russia.
Fixes: 384
And people believe what computer programs tell them. Duh.
Quote from: Strat
If the Gulf Stream fails, as the basic physics says it will, we'll certainly feel the chill. It's already showing a 30% slowdown in the last ten years.
James
Doesn't the gulf stream also determines the depression track, which is supposed to shift north during the summer months?
I'm only going on personal experience rather than having any evidence whatsoever, but the shift northwards seems to have been lesser over the last few years.
No, that's the Jet Stream James. It's been more southerly in the early part of the year than usual which caused low pressure areas to cross over the UK, and more northerly in the last six weeks which pushed the bad weather over Scotland and to the north. The Gulf Stream is a flow of warm water that originates in the Bahamas area and travels past Britain to Greenland.
Jet stream seven day forcast can be found here: - http://www.metcheck.com/V40/UK/FREE/jetstream.asp
We either want the red bit well north of Scotland or somewhere through central France.
The Gulf stream known also as the "North Atlantic Thermohaline Circulation" is the northern part of the northbound surface current, before the current dives deep off the coast of Greenland and heads back direct to the south Atlantic.
seen here  http://www.appinsys.com/GlobalWarming/GW_4CE_NATCGulfStream.htm
Good powerpoint description here
http://www.meteo.mcgill.ca/~tremblay/Courses/ATOC530/EuropeClimate.ppt
Just wish GB was not involved in Fixing climate change.
Quote from: nozzer
Yes, that as well, The Northeast Passage has been opened since the very late 1800's and regularly since 1935, mainly by Russians.
If you Google Northeast Passage there's a Hutchins Encyclopaedia entry for the history. Agreed western ships have only recently begun using it.
