The planet can be saved
- General Chat
- Re: The planet can be saved
19-10-2009 1:03 PM
19-10-2009 1:06 PM
19-10-2009 1:10 PM
19-10-2009 1:35 PM
but that's not the point.
19-10-2009 1:38 PM
Customer and Forum Moderator. Windows 10 Firefox 70.0.1 (64-bit)
Life is tough enough without adding Linux into the mix.
19-10-2009 1:42 PM
19-10-2009 1:43 PM
Quote from: Petlew One of the doom-mongers favorite arguments is the navigation through the ice of of the North West Passage, which is possible now...shussh! don't shout it around but, it has been navigable since 1903-6 and routinely since 1934.
Ermm.... it's the North EAST passage that's just becoming navigable actually, over the top to the Northern coast of Russia.
19-10-2009 1:45 PM
19-10-2009 1:45 PM
Quote from: Strat and they are now talking about Global Cooling
If the Gulf Stream fails, as the basic physics says it will, we'll certainly feel the chill. It's already showing a 30% slowdown in the last ten years.
19-10-2009 2:08 PM
I'm only going on personal experience rather than having any evidence whatsoever, but the shift northwards seems to have been lesser over the last few years.
19-10-2009 2:17 PM
19-10-2009 4:56 PM
We either want the red bit well north of Scotland or somewhere through central France.
The Gulf stream known also as the "North Atlantic Thermohaline Circulation" is the northern part of the northbound surface current, before the current dives deep off the coast of Greenland and heads back direct to the south Atlantic.
seen here http://www.appinsys.com/GlobalWarming/GW_4CE_NATCGulfStream.htm
Good powerpoint description here
http://www.meteo.mcgill.ca/~tremblay/Courses/ATOC530/EuropeClimate.ppt
Just wish GB was not involved in Fixing climate change.
19-10-2009 6:24 PM
Quote from: nozzer
Yes, that as well, The Northeast Passage has been opened since the very late 1800's and regularly since 1935, mainly by Russians.
If you Google Northeast Passage there's a Hutchins Encyclopaedia entry for the history. Agreed western ships have only recently begun using it.
