The dangers of DHMO...
twocvbloke
It's lethal stuff!!! Crazy
6 REPLIES 6
Fixes: 191
Re: The dangers of DHMO...
You must admit that totally immersion in it for several minutes without the proper PPE always ends in a fatality.
Minesapint
Water load of. . . Grin
Minivanman
Aspiring Legend
Well given that around 55m people die each year anyway, I'll not worry about it to much m'self. Smiley
Don't limit the friends you haven't met with arguments you'll never have.
twocvbloke
It's the perfect example of the "daily mail effect", where if someone professes something perfectly innocent, harmless and normal to be bad and evil, the lesser educated, or just plain ignorant, will believe it... Grin
RobPN
Fixes: 5
@twocvbloke wrote:
... the lesser educated, or just plain ignorant, will believe it... Grin
I suppose you could say they'd also be a bit wet behind the ears.  Cheesy
billnotben
Does it make your wrists go all loose and your hands flap about?
If so that presenter has well overdosed.
