The Known Universe
Fixes: 188
The Known Universe
I love this kind of thing
Customer and Forum Moderator. Windows 10 Firefox 64.0 (64-bit)
Re: The Known Universe
Good find Strat!  Wink
Geoff,
York.
Made the hairs on the back of my neck stand up!  Smiley Smiley Smiley
To do is to be - Neitzsche
To be is to do - Kant
do be do be do - Sinatra
And this one might make you think a bit!  Carl Sagan's "Pale Blue Dot" message at the end of a long-gone TV series.
Fixes: 9
Excellent video not easy to imagine something that has no end.
Also makes you think how insignificant we are in the universe
Fixes: 188
Not easy to imagine space with no end.
If you come up against a brick wall....what's behind the wall Wink
Fixes: 251
I remember as a child trying to imagine what if the universe didn't exist - that was also mind-blowing  Shocked
Forum Moderator and Customer
St3
Aspiring Champion
Fixes: 5
Enjoyed that was really chilled out Wink
Fixes: 38
These are great videos, that make you think, and with that said;
If the Universe as we know it started from a singularity, what made the singularity, was it the result of a previous collapse?
In a lecture given in 1996 by Stephen Hawking he hints that the Universe may come to an end and collapse in on itself in about 20B years, so if this does happen is the cause of this collapse a result of the Universe reaching its maximum size, and bursting like a balloon? If that is the case then the Universe in not infinite!
Then throw into the mix the 'Phase Transition'!
Mook
