Tesco Direct & FF
Fixes: 232
Tesco Direct & FF
Is anyone else having issues accessing Tesco Direct using FF (10.0.2)?
The problem persists whether I click on a link from the main site or enter the URL directly.
Since yesterday I just get the error below.
No problems with IE9 or Google Chrome.
Forum Moderator and Customer
Fixes: 311
Re: Tesco Direct & FF
Safari, Firefox and chrome have been problematic for me with Tesco direct, I have to resort to using windows and IE for one site.
I suspect it's something to do with it been based on .net but Tesco don't want to know.
Customer / Moderator / If it helped click the thumb / If it fixed it click 'This fixed my problem'
Fixes: 232
It's strange as I've never had a problem using FF with Tesco prior to yesterday.
At least I know it's not my system Cool
Thanks dvorak
I don't normally use Tesco Direct, but I thought I'd give you some more ammunition by trying it. But it worked perfectly in my FF.
anniesboy
OK here also
Fixes: 232
So strange as this issue has continued after a reboot and I have also cleared all Tesco's cookies.
anniesboy
Check it out with this.
http://is.gd/07CtLW
Fixes: 4
It's working perfectly for me  Huh
Firefox 10.0.2 on Ubuntu 10.10
Working fine for me on FF 10.0.2
Fixes: 232
Quote from: anniesboy
http://is.gd/07CtLW
I know the site is up as I can access from IE and Chrome. But I checked anyway and no problem with site just FF won't go there for some reason.
Infinity
Seasoned Pro
Any problems with such websites, I enable cookies, works every time.
I use Camino on my iMac, same stable as Firefox.
I regularly delete all my cookies, then re-authorise.
