Tanin in a china tea pot
Fixes: 16
Got an old china tea pot.... been using it for years... and as you can imagine...there is a build up of tanin on the inside... this is starting to flake off, and bits appear in the bottom of the cup... no problem there.. I don`t drink all ! ! .. ( just keep topping up ! ! ! )..
Any one know of a good way to clean out the old stuff... ?  ( I suspect the biggest deposit is in the bottom curve of the spout )...
Re: Tanin in a china tea pot
Fixes: 16
Great idea...... now I have to find a relative who can give me a Dishwasher tablet ! ... !  !  !  ..
Thanks for the vid linky ....  Wink
nanotm
or you could try using boiling water and vinegar (which is also a great way to descale the kettle) then wash out the teapot to get rid of the vinegar taste.
using things like a dishwasher tablet is fine if your teapot has no scratches in it from stirring overzealously but if you do then chances are it will ruin the pot /
Fixes: 20
Or some hot water & baking soda leave it in for a while rinse and check.
If it's that bad I would buy a new teapot. They are not expensive.
Fixes: 16
Nah... can`t afford one ... and.. it makes a good cuppa ! ! !..  Cheesy
I bet it's got sentimental value!
SWMBO has cleaned her (non-china) tea mugs using some of her fathers Sterident* (or more likely a cheaper brand from Lidl**) tablets. Took a while and a few tablets but did the job.
* Other brands are available
** Other budget shops are available
F9 member since 4 Sep 1999
F9 ADSL customer since 27 Aug 2004
DLM manages your line the same way DRM manages your rights.
Look at all the pretty graphs! (now with uptime logging!)
Fixes: 168
Quote from: nozzer
Should that not be sedimental value Cheesy
Forum Moderator and Customer
Fixes: 16
And the good news is......... The Dishwasher tablet with boiling water did a super job... looks brand spanking new inside now.... left it for about 45 mins while I had a shower, and just washed it out... loadsa muck !... now boiling kettle again for a good rinse out, and a special celebratory brew shortly ! ! ...
This forum is BRILL ! ! ! .. Smiley Smiley Wink
You missed a trick there. You could have used the effluent to make a refreshing tannin-rich drink! Cleans your teeth as well.
A good Tip then Wink
Fixes: 16
Pretty Good !
Leaf it out, it was better than that Wink
