Take a peek at this
Take a peek at this
Have a look at Google Earh of Davis-Monthan afb. see how many types you can identify...
pierre_pierre
Re: Take a peek at this
are referring to types of map, cars, people, or aircraft?  also plain google maps have the same sat view
Fixes: 174
It's an amazing place Shocked
Customer and Forum Moderator. Windows 10 Firefox 64.0 (64-bit)
pierre_pierre
Mon Feb 05 18:13:16 -0800 2007
someone asked if there is a list of the planes and what types they are, if you use google earth and have the checkbox for google earth community checked, you will see posts where people have named each type of aircraft.
Thank you pierre.
Petlew sighs deeply.
'Peek' - ah memories , memories,
did you 'peek' and 'poke' back in the 80's
The joys of Basic - NOT
I preferred to push and pop in Z80 assembler
/coat
