TVGuide
Fixes: 192
TVGuide
I use TVGuide.co.uk but today BBC1 and BBC2, normally at the top of the list, are not showing anywhere.
I've checked my setting which have BBC1 & 2 SE ticked. I resaved settings but still not there.
Anyone else seeing this?
Forum Moderator and Customer
Re: TVGuide
@Mav, do you have to register to use this guide?
Fixes: 192
Re: TVGuide
No.
I have found it quite useful as you can modify the layout to suit.
Edit: There is an option to register but have no idea of any benefits from doing so.
Fixes: 17
Re: TVGuide
I haven`t registerd.... but my version is different to yours... and there is a change with all those red hearts making it difficult to read now... so looking around for something else...
As you see.. BBC1 and BBC2 seem to have disappeared...  Undecided
http://www.tvguide.co.uk/?systemid=3&cTime=8/17/2011%206:00:00%20PM&thisTime=&thisDay=&catColor=
Fixes: 10
Re: TVGuide
BBC1 and BBC2 are both missing for me too.
Fixes: 17
Re: TVGuide
Just had a scan at your original and if you scroll down to the bottom of the listings.... there is a white box.... "Add channel"... so looks like you have to add your "LOCAL" BBC station(s) manually....
Fixes: 192
Re: TVGuide
Already tried that - didn't make a difference Sad
Fixes: 17
Re: TVGuide
Yay... I did too, and I got a load of stations I cant get.... RTE  one  etc  ( Radio Television Eire .... in Portsmouth  ? ?? )  so I have now got this one as my guide
http://tvlistings.guardian.co.uk/
Different layout... but you set your tv area and your supplier (freeview/sky etc) and then you click on the prog description to see what is the content... a new page opens (rather than the small box on tvguide).... and for soaps, like emmerdale, you can actually watch previous episodes in a "catch up" box,  very handy....  better than tv guide...
I do wish they would put the channel numbers on the stations listings, though....
Fixes: 192
Re: TVGuide
Thanks for that.
But I really liked TVGuide.co.uk, why did they have to mess with it? Cry
Fixes: 17
Re: TVGuide
Yeah me too....  Cry
Fixes: 192
Re: TVGuide
We need a group hug icon  Cool
Fixes: 17
Re: TVGuide
Better still... have this one....
http://www.radiotimes.com/tv/tv-listings
Much simpler layout... with channels listed similar to TV guide.... also clicking on the prog opens a new page with info... and scroll down , you can get "spoilers"... i.e. what is coming up in the future on the soaps.... ( never want to know that really )...
Fixes: 192
Re: TVGuide
Thanks.
Looks ok to me Smiley Suppose I just got used to TVGuide Roll eyes
Infinity
Seasoned Pro
Re: TVGuide
I swear by TV-Browser.
By far the best TV-Guide there is, you download info, and use it off line.
Takes a bit of setting up, but well worth it in the end.
It is so versatile.
I run 3 separate versions for Freeview, SKY  & Films, they can all be open at the same time too.
http://www.tvbrowser.org/
Fixes: 192
Re: TVGuide
Panic over.
BBC1 & 2 are back Smiley
Thanks for all the other suggestions and will try them out and see what's best. I may even do a poll later Wink
