TV/Skype
TV/Skype
For sometime SWMBO and I have Skype'd our daughter in New Zealand and other family. For various complex reasons related to Mrs P disabilities balancing a PC on her lap is quite difficult without it wobbling all over the place and the loose fit camera constantly falling off.
It occurs to me that I should I think be able to set up our fairly new TV as a PC monitor and set the camera on a small tripod or fixture for her.
However, the Skype and camera connection would still need to be through the PC. With an available TV manufactures LAN adaptor (would need to obtain) Can I set the TV to my home network and transfer the PC image to the TV. Or I can I think set the whole thing via USB cables.
Any ideas?
Fixes: 10
Re: TV/Skype
Some internet ready TV's support Skype directly - have you checked if yours does with the LAN adapter?
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
Re: TV/Skype
The adaptor is an optional extra, it might well but I haven't ordered one yet. I must look into that ASAP.
VileReynard
Seasoned Pro
Fixes: 11
Re: TV/Skype
Why not just put a laptop on a table; with an associated chair it would work well. Cheesy
Fixes: 55
Re: TV/Skype
If the TV has a VGA input then what about a long VGA cable ?
Or a long HDMI cable if the PC has HDMI output
Fixes: 225
Re: TV/Skype
Have you looked at one of these?
I have something similar at home. I'm out at mo but when I get home I'll look for the details and photo. What I have is great for use in bed or even sitting in a chair.
Forum Moderator and Customer
Re: TV/Skype
Thanks guy's...
No HDMI output on PC sadly.
Think TV has VGA input, will look into this.
@Mav, thanks but I'm trying to discourage Mrs P from becoming bed-ridden any more than necessary, although I admit it would work I expect.
Have emailed Samsung helpline to ask if their LAN adaptor has Skype in-built, but the available information doesn't mention it.
For later today using a high stool (a variation on Un renard, c'est le Mal's suggestion) for PC and mounted camera on tripod, looks as if it will work, a bit Heath Robinson but effective.
Re: TV/Skype
Found this on ah hem! Skype's website, but at £179 its a bit pricey for occasional use: http://shop.skype.com/intl/en-gb/skype-for-tv/tv-compatible-webcams/logitech-tv-cam-hd/
Re: TV/Skype
Also from Amazon it seems (what isn't): http://www.amazon.co.uk/Logitech-960-000924-TV-Cam-HD/dp/B008VS899W/ref=sr_1_1?ie=UTF8&qid=135653632...
Same price, with some very very enthusiastic reviews.
The question is; is it worth the expense?
Re: TV/Skype
I know its expensive, but there were other considerations other than cost involved with this,
After some umming and arrhing we took the plunge and purchased the Logitech TV cam kit, and are we pleased we did...
Remember it only has one function in life; to bring Skype to your TV screen, which it does brilliantly.
Most importantly, SWMBO is delighted.
Recommended if the cost doesn't put you off.
Fixes: 247
Re: TV/Skype
if it does what you want and you are happy with it, then it's not too expensive and it's good value for money Smiley
glad it has worked out for you and Mrs P.
Customer / Moderator / If it helped click the thumb / If it fixed it click 'This fixed my problem'
nadger
Re: TV/Skype
As has been said the price isn't important if Mrs P is happy and can communicate readily with your daughter and other family members.
I think our current tele needs an upgrade http://www.bbc.co.uk/news/technology-20957218
Fixes: 19
Re: TV/Skype
So, how do 13,000 people still manage to watch b&w tv.... since the digital system?  can they/do they,  use a digi box?
nadger
Re: TV/Skype
Would indicate that a Freeview box will work with b&w but don't know anyone who's tried.
When I first started work in Jan 1952 it was with Ultra Electric and tvs they made were built like tanks.
They put in an overhead conveyor system to carry tubes to production line and sometimes one would fall off. Sounded like bomb going off.
198kHz
Aspiring Champion
Fixes: 11
Re: TV/Skype
Quote from: shutter
Yes. A digibox will output a colour signal, which the B&W set will accept via the aerial socket and show in monochrome. Just the same as receiving off-air when the signal was analogue.
Provided, of course, that the box has an RF modulator - not many of the current models do.
Remember you are unique - just like everyone else
