TV Reception
Fixes: 9
TV Reception
Recently we have been getting poor reception on some TV Channels at random times, there must be at least a 100 different reasons why this might be happening and it's not easy to know where to start.
The Only electrical item that has changed in the house since this started are the router and modem for fibre but I cannot see this being the problem and assume it's a coincidence ?
Any thoughts on what is the most likely thing it could be ?
Smiley
Fixes: 50
Re: TV Reception
I have a TV in the living room and one in a bedroom.
Recently I started having reception problems and traced the problem to a failing aerial splitter/booster.
Replacing it restored good reception.
Do you have such a device either near a TV or on the aerial mast.
Customer and Forum Moderator.
Fixes: 9
Re: TV Reception
No splitters or mast amplifers but it will cost me nothing to check out the cable connections to the aerial.
Fixes: 12
Re: TV Reception
4G interference maybe?
or could be the aerial has moved slightly.
if it's happening on Dave or Dave ja Vu, then i'll most likely be an aerial out of alignment by a few mm's... although that would happen all the time rather than just some of time, unless it's atmospheric issues causing it.
alanf
Re: TV Reception
Quote from: chenks76
Site to search to see if your area could  be affected by recent changes. If this is the cause of the problem then free filters may be available.
https://at800.tv/
Fixes: 9
Re: TV Reception
Thanks,
Some good information on that link.
Re: TV Reception
Aerial fallen off the roof?
Fixes: 9
Re: TV Reception
A far greater chance of me falling off the roof than the Aerial.
Smiley Smiley
Fixes: 30
Re: TV Reception
Well be careful when / if you go up there, it killed Rod Hull!
Fixes: 50
Re: TV Reception
Not so serious for emu I would guess Lips are sealed
Fixes: 30
Re: TV Reception
Well apparently he was going to be going up to the roof till the doofus remembered he couldn't fly!
Re: TV Reception
Did emu ever audition for a new partner?
Fixes: 142
Re: TV Reception
Apparently so...
...but the poor fellow got the bird Cheesy
Forum Moderator and Customer
Re: TV Reception
Is your aerial outside?
Could be a bit of windy weather has shifted it slightly.
I had the same with Sky, the brackets holding up my aerial pole were shit (Sky dish is attached to it).
Knocked out Sky complely.
I wasted £65 on Sky coming to realign the dish (now I realised that didn't fix the real problem), so it worked for a few weeks then went down again. I used to mess around readjusting it myself. Good thing about living in a bungalow is I didn't have to climb too high Grin
In the end I spoke to a local hardware store with a iPhone picture of what I had and he told me no wonder it was bad and sold me two hardcore brackets. Got a builder friend to fit them and he also aligned my dish using a iPhone video call so we could see my signal menu while he was on the roof.
Worked fine ever since and I still have a better signal than I had when Sky realigned my dish.
