TIFF to JPEG
Fixes: 9
TIFF to JPEG
Is there any simple (and free) way to convert TIFF files to JPEG
These started off as RAW Files but Photomatix was used to convert them to HDR and then through Photomerge in photoshop so ended up as massive TIFF files.
Any help would be appreciated.
Fixes: 62
Re: TIFF to JPEG
FastStone Image Viewer will do that individually or as a batch convert http://www.faststone.org/ with full control
Re: TIFF to JPEG
Presuming you're using a Windows machine, MSPaint can open .tiff files and save as jpeg.
If you want to make other tweaks or have bit more control over the compression try Paint.net - a very good and free image editing program.
Irfanview can probably do the conversion quickly too.
pierre_pierre
Re: TIFF to JPEG
IrFan View  http://www.irfanview.net can read virtually any image file and save it to another and its free
Fixes: 17
Re: TIFF to JPEG
I`m with Pierre, on that.... Irfanview is free, and can do "batch conversions" if necessary from any format to any other format... simple to use,  (that`s why I use it ! ! !)  Cheesy
http://www.irfanview.com/
If you down load it, then download the "plugins" they go straight into the folder for you..............no problem... Wink
