TFL: Victoria Line broken
Just for any Londoners/commuters out there:
No service between Warren Street and Brixton while we fix damage caused by Flooding at Victoria.
This is the cause (apparently) - http://usvsth3m.com/post/74285062011/you-wont-believe-why-the-victoria-line-is-currently
Very hard to believe, no?
Re: TFL: Victoria Line broken
Ouch... that's gonna be expensive CU in court Mr Contractor.
Now Zen, but a +Net residue.
Fixes: 168
Quote from: AndyH
Guardian are reporting the same - http://www.theguardian.com/uk-news/2014/jan/23/londons-victoria-line-suspended-after-control-room-is...
Well, that's concrete proof Cheesy
Forum Moderator and Customer
Some funny comments out there:
According to latest reports, ASLEF's stance on this issue is hardening.
They have plans to reopen soon, but nothing concrete. Oh hang on ...
Fixes: 168
Has the contractor admitted who was asphalt Tongue
alanf
I was reading in last night's Standard about Bombardier withdrawing from the contract to resignal part of the Underground and mention was made that  "The project was to have emulated the success of new signals installed by Siemens on the Victoria line, which now boasts Europe’s highest-capacity subway service at morning peak." So it is the newest finest signalling equipment that will have to be replaced not the stuff that needs replacing anyhow.
http://www.standard.co.uk/news/london/tube-fiasco-prompts-fear-that-signal-upgrade-will-miss-2018-de...
Update: Phew! There is no talk of long-term disruption so it seems that it is not the most hi-tech bits of equipment that have been affected.
Standard's report on this incident.
http://www.standard.co.uk/news/transport/huge-delays-as-victoria-line-as-concrete-leak-hits-control-...
TORPC
Could this of been inadvertent sabotage ?Huh
@ Alan I would have thought there will be major problems as concrete is a pita to clean (once it begins to go off, you're in deep doodoo). Over electricals, I would have though the only option would be to replace them as you won't be able to hose them down.
@ TORPC I think more incompetence. They were filling voids with concrete. Just turns out one of those voids was the signal room Cheesy
Fixes: 10
There were some good comments on the Guardian website - I liked the ones that suggested it will be renamed the Blue Circle Line.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
alanf
I liked the less obvious one. "We'll have to take the repla-cement bus."
alanf
Quote from: AndyH
Yet this morning.... 'Peter McNaught, operations director for the Bakerloo, Central and Victoria lines, said: "Our engineers have worked tirelessly through the night and have successfully repaired the damaged signalling equipment. A good service is now operating across the Victoria line.'
http://www.telegraph.co.uk/news/uknews/road-and-rail-transport/10593858/London-Undergrounds-Victoria...
Fixes: 10
[quote=http://www.standard.co.uk/news/transport/workers-bought-sugar-from-supermarket-to-slow-cement-flood-farce-on-victoria-line-9081168.html]Contractors rushed to the supermarket to buy sugar to slow a flood of fast setting cement which was accidentally pumped into a control room at one of London’s busiest Tube stations.
Looks like they acted quickly enough to get it out before it set.
That's amazing about the sugar - never realised it was a retardant for concrete.
Credit to them for fixing the problem...but what a balls up in the first place.
nanotm
its not the first time something like this has been done on the underground, a few years ago I seem to recall there was a similar story about how the signalling equipment was supposed to be given plastic covers and then the space around it backfilled with concrete to prevent water damage during floods and someone mistakenly filled 2 blocks with concrete prior to the covers being fitted.......
I don't actually understand why you would fill in the areas if they were designed as holes, just because a few tramps have been found lurking in them, there meant to be there for emergency use or equipment storage during shutdown maint times in busy routes.....no doubt someone figured out that terrorists could equally use them for bomb planting so instead of upping security there just removing the hidey holes ...
