Surgical dexterity and smartphones
Jonpe
Fixes: 9
One of the unexpected effects of smartphones: https://www.independent.co.uk/life-style/surgery-students-dexterity-smartphones-keyboards-screens-cr...
Professor Kneebone, an apt name for a surgeon (orthopaedics perhaps).
5 REPLIES 5
nozzer
Re: Surgical dexterity and smartphones
One thing I have noticed everywhere is that the youngsters seem to be able to use their thumbs very rapidly for typing on a screen. I've tried it and mine don't seem to go in the right direction! Undecided
gleneagles
Fixes: 16
Perhaps stitching is on the way out ?........Metal clips and superglue might replace the stitches
Wink
We are born into history and history is born into us.
petlew
They already have Gleneagles. Had double hernia surgery last month, and glue (I'm told it was a variant of Superglue) was used to join internal incisions, only the final surface was stitched with dissolving sutures, and they only really to hold the glued edges together for healing.
For years I haven't used plasters for minor cuts, but a substance from a bottle called "Newskin", which is basically a glue that forms a seal, wearing off fairly quickly after the bleeding has stopped to allow natural healing. Stings a bit when first put on though.
Mind you, I had seven hours of spinal surgery in 2000, Given I can't see it very well even in a mirror, but I got someone to photograph it, and the incisions look as if they were stitched with rope.
Jonpe
Fixes: 9
Wink
Metal clips in plastic surgery would probably make Frankenstein's monster look aesthetically pleasing?
Luzern
Fixes: 9
Another thing for robotics?
