Strange setting!!!
Strange setting!!!
Every time I click my "home" page in FireFox the "Tools/Options" menu bar tab is added to the menu bar. It doesn't open unless I click the tab. I can end up with dozens of these tabs all quietly sitting in the menu bar if I fail to remember to close the tabs.
I'm not sure why its happening, or what setting to change to stop it, there's nothing obvious in the Options page.
Any one here know?
9 REPLIES 9
Re: Strange setting!!!
Not behaviour I've ever seen ..
I assume you don't have Settings as your home page.
I would start with disabling any add-ons, see if that fixes it.
Fixes: 491
Not sure why you get multiple 'Options' tabs.
However I did notice a few weeks ago while setting up my Home tabs that the 'Options' page which I had open in order to perform this operation was added as a Home tab Huh
I had to go into Options and edit it off the list.
It didn't used to do this so I suspect a bug.
I use Waterfox, a 64 bit Firefox variant.
Customer and Forum Moderator. Windows 10 Firefox 84.0.2 (64-bit)
Any good?
https://support.mozilla.org/en-US/questions/1063841
  Chosen solution
Hi, FredMcD's advice is what you need: You can go back to the old Options window by: Type about:config into the address bar, press Enter, accept the warning, scroll down to browser.preferences.inContent and double click to change 'Value' from True to False, taking care not to alter anything else. You may then need to restart Firefox.
Whenever I've had a problem with Firefox or Thunderbird I've posted my query on the Mozilla forums. Always got an answer from a well informed  person, generally one of their mods
http://forums.mozillazine.org/
Interestingly (or otherwise depending on your point of view) I don't have "browser.preferences.inContent" to change to false in my "about:config" list. However my Firefox is v44.0.2 that referred to in the link is v38. So maybe there's more information in artmo's suggestion.
But, thanks for the suggestions guy's.
That was removed in v42.
S'pose you wouldn't know what replaced it?
No idea.
Firefox has become a bit of a mystery to me so I stick with an old version of Palemoon.
I only use the latest Firefox when I'm forced to.
Even then it's only a brief use of a stand alone version.
Well, WFT and Strat between them had the answer, And predictably was dead simple. My home page in "Options/General" was suffixed with the Options URL, leading to both being opened every time the home page was clicked. The Options tab was cumulative though.
a) I hadn't noticed.
b) how it got there I have no idea.
I did though recently have to reset my home page as a software down load loaded itself as my home page, without any indication in its setup it was going to, something I find very annoying.
Thanks guys.
