Sticky Radio Problem
Luzern
Fixes: 9
In our bedroom we have a  Pure internet radio. It has a hard black matt case. My wife has noticed the case has acquired a slightly sticky feel, but nothing is obvious. Could it be a result of the hot weather? I can't think it's us, as it's not handled with dirty mitts.
Wiping it does nothing, so what suggestion can anybody make for its cleaning, please?
3 REPLIES 3
shutter
Fixes: 47
Re: Sticky Radio Problem
If it is "parked" in the sun......... i.e. in a window space, where the sun comes in all day,...then the plastic ( or the lacquer finish/ surface ) has probably deteriorated, due to the heat... it is quite something when black items are left in the sun, even for short period of time..
As for "cleaning" it.... dunno !... maybe leave it in a cooler place... to see if the plastic ( or lacquer finish/surface)  resettles back to original,... if so,  some serious work with a sander may be possible, and then a coat of good furntiure polish..... but keep it out of the sun from then on ...
harrym1byt
If it originally had a soft rubbery surface, then all those finishes go the same way - even softer and much stickier. All you can do is put up with it or chuck it away. A dusting of talc might help though.
RobPN
Fixes: 5
I had a couple of BT branded Binatone DECT handsets which were described as 'rubberised' and which looked as described when they were new.  However it didn't take much handling and sliding into a trouser pocket for the very thin rubberised coating, which turned out to be about as thick as a coat of paint, to wear away in several places..
When that happened it started to make the handsets look a little tatty so I decided to rub it all off which was quite easy using a bit of cotton rag.
Edit: corrected brand name.
