Spray plaster
- General Chat
- Spray plaster
Spray plaster
Spray plaster
09-09-2013 7:11 PM
Never heard of it before - has anyone here tried it? How well does it work? How long does it last (does it wash off easily)? Is it any good?
Edited wrong link
Forum Moderator and Customer
Re: Spray plaster
Re: Spray plaster
09-09-2013 9:40 PM
I tend to use it when I have a long scratch from briars or barbed wire as it stops the blood pouring all over my clothes
It doesn't wash off easily but can be pealed off when needed
Re: Spray plaster
Re: Spray plaster
10-09-2013 9:58 AM
But I digress. I usually use a paint on substance called New Skin, but not for a long time, the only entry for I could find is an American site http://www.drugstore.com/new-skin-first-aid-antiseptic-liquid-bandage/qxp13279
Don't know if its still available in the UK now.
Re: Spray plaster
Re: Spray plaster
10-09-2013 10:00 AM
Customer and Forum Moderator.
Re: Spray plaster
Re: Spray plaster
10-09-2013 10:02 AM
Re: Spray plaster
Re: Spray plaster
10-09-2013 10:03 AM
Re: Spray plaster
Re: Spray plaster
10-09-2013 10:06 AM
Re: Spray plaster
Re: Spray plaster
10-09-2013 12:53 PM
Broadband Service Manager
Re: Spray plaster
Re: Spray plaster
10-09-2013 1:05 PM
Re: Spray plaster
Re: Spray plaster
10-09-2013 7:25 PM
Should not be drunk
Re: Spray plaster
Re: Spray plaster
10-09-2013 7:52 PM
Quote from: AlaricAdair Should not be drunk
would you get plastered ?
Re: Spray plaster
Re: Spray plaster
10-09-2013 8:40 PM
