Spot the connection
Fixes: 10
Spot the connection
Another little puzzle for you to work out. What links these two pictures?
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
Fixes: 247
Re: Spot the connection
either
a) they're both in a post by jelv
or
b) eating disorders.
Customer / Moderator / If it helped click the thumb / If it fixed it click 'This fixed my problem'
Fixes: 10
Nope - there's a very specific connection.
Lurker
They both wear a thong to work?
Fixes: 247
the models waist is the same size as one of prezza's thighs?
Lurker
I've studied some background info on both of them, and it seems the images are to the same scale too.
WAIT - BACKGROUND!!!ONE!
A: They are both pictured against a dark background. Smiley
Fixes: 10
Quote from: St
No that's not it (in any case her waist isn't that big).
Fixes: 10
A clue: It's topical and not unrelated to another post I've recently made on these forums.
Fixes: 10
Any more guesses?
When the answer emerges I can guarantee it will generate some discussion!
Fixes: 21
He drinks lots of beer which contains DHMO, she won't go near DHMO and signed the petition.
So the answer is DHMO.
Fixes: 10
Not that recent - it was earlier this week - not in a board I usually post in.
It's Google.
The new picture-matching "feature" thinks they are similar - about 50th in the list when I looked.  Crazy
(though mostly it's Renee Zellweger)  Crazy  Crazy
Fixes: 10
Correct!
http://similar-images.googlelabs.com/images?q=john+prescott&hl=en
Take the Similar Images link under John Prescott's Battle with Slimmers then go to the second page of results.
I think they have some work still to do on this technology!
