Spot the Difference
Spot the Difference
Google has changed its logo.What do you think of the new one?
Changing Logo
Fixes: 196
Re: Spot the Difference
I must say, I preferred the old one Tongue
Forum Moderator and Customer
You've got to keep up with the times Mav Wink
Fixes: 224
Quote from: Mav
How can you say that? the new one is much more awesome!!
Customer / Moderator / If it helped click the thumb / If it fixed it click 'This fixed my problem'
198kHz
All Star
Fixes: 10
That's awesome.  Roll eyes
Remember you are unique - just like everyone else
Fixes: 196
Quote from: dvorak
I don't like a lot of change in things - gets me all of a kerfuddle
Google must have a secret agenda somewhere. Maybe to make the logo look better on Samsung curved screen TV's.
That's it then, off to buy a curved screen TV. The new logo is all I needed to push me over the edge.
I always thought google needed a 'g' up!  Cheesy Grin
To do is to be - Neitzsche
To be is to do - Kant
do be do be do - Sinatra
Gee, that's fantastic!  Grin Wink
Geoff,
York.
it's an 'l of a change though Smiley
