Spot The Difference - then explain it please
shutter
Fixes: 47
Here is a pic of my laptop showing two versions of the forum...
3 REPLIES 3
Re: Spot The Difference - then explain it please
Missing Avatars, @shutter are you still using the CSS code that hides these in the plug-in?
shutter
Fixes: 47
I "think" I am using the same background colour code on both FF and Pale moon... but  I could be wrong.... there may be two copies on my folder with the same/similar name...
Thanks for the pointer.. will check it out.
shutter
Fixes: 47
Thanks Mook.... got the same version ( different titles). running on both FF and Pale Moon now... Wink
