Spooky Electronics
Strat
Fixes: 506
Spooky Electronics
I just plugged a laptop into the mains, connected a network cable and switched it on.
The TV across the room, which is networked, promptly switched into standby and back on again.
I seem to recall it doing so once before some time ago.
Spooky.
Customer and Forum Moderator. Windows 10 Firefox 88.0.1 (64-bit)
9 REPLIES 9
rongtw
Fixes: 12
Re: Spooky Electronics
@Strat gremlins Smiley
Strat
Fixes: 506
Would those be the same gremlins who knitted a scarf out of all the cables behind the TV.
Fixes: 73
Most definitely , Strat - same little horror that mix all my  cables in the 'office' -even though all I do in there these days is turn on the printer.
adamwalker
Fixes: 128
if @MatthewWheeler doesn't come along with some puns about this I'll be VERY disappointed Smiley
 Adam Walker
Mav
Fixes: 431
Time to invest in some cable ties Wink
Forum Moderator and Customer
Fixes: 73
Have you any more garish ones, @Mav -those are a bit muted for my tastes? Mind you, the gremlins might like 'em Cheesy
Mav
Fixes: 431
Having been dogged with bad luck with my cables I think one of these will do:
Got a plug socket in my attic that trips the rest of the house when you plug something into it and turn it on. But that's just because of a bad wiring job by the previous owner (who incidently is dead, so possibly haunting just that one socket).
twocvbloke
When I switch on my HP Laser printer, my IP Camera over the door crashes and takes a while to reboot, no idea why, so I just leave the printer on, uses naff all when in sleep mode anyway...
