Spellcheck
Spellcheck
Is there any way to get the spellcheck to check automatically as it did in the old forums?
5 REPLIES 5
Fixes: 21
Re: Spellcheck
If you are using FF is does just that.
Some tips here btw.  Also clicking on the ABCtick in the toolbar activates the in-built checker.
Re: Spellcheck
Mine doesn't do so. I've gone into tools>Options>Advanced and ticked check spelling as I type.
Fixes: 21
Re: Spellcheck
Have you got a dictionary loaded and active?
Re: Spellcheck
Yes, it's working elsewhere but not on the forums.
Interestingly I've just noticed spellcheck is working fine on my W10 laptop but not on my W7 machine.
Re: Spellcheck
Ah!! Found the solution. Just re-installed the dictionary and now spellcheck works fine.
Thanks for your help.
