Speeding fines - is this fair
- General Chat
- Speeding fines - is this fair
21-03-2017 7:19 PM
Or if you are caught going between 31 and 40mph in a 30mph zone you will get three penalty points and a fine of between 25 and 75 per cent of your weekly income.
Re: Speeding fines - is this fair
21-03-2017 7:26 PM
The obvious problem with this is that 75% of £0 is £0. Easy enough to solve that by specifying a minimum, for example 75% of weekly income subject to a minimum fine of £200.
21-03-2017 7:30 PM
I'm not a driver, so it won't affect me. However, it does seem unfair, and as your speedo has a tolerance, how the heck can you control your speed reasonably - I don't mean someone doing 70 in a 30 limit zone, but an indicated 28 in a 30 zone, and getting 'caught' for doing 31 - not possible, even speed cameras are not that accurate!
21-03-2017 7:35 PM
I regularly go past one of those speed displays in a 40 MPH zone where my speedo indicates just below 40 (so possibly doing less - 36 or 37) yet the bloody thing still flashes up the 40MPH display.
Either my speedo is underestimating or the display is calibrated wrong.
Forum Moderator and Customer
21-03-2017 7:38 PM
There "used to be" an allowance of !0% inaccuracy on speedo readings, compared to actual road speed, however, I am not sure if the modern day speedo`s ( speedometer - not clothing )... are covered by this "allowance" due to modern technology.
I checked my speed at 30mph, showing on the dial, and compared that to the speed shown on my sat nav (Garmin).. it was 28mph... at 60mph on the dial, the satnav was showing 58mph.
21-03-2017 7:40 PM
No... your speedo is not underestimating.... it is a "movement sensor" triggering the showing of the 40 limit sign.. same as those for road junctions that light up as you approach them
the true "speed display" signs do actually use a radar signal to check your approach speed, and this is shown on the screen as you approach.
21-03-2017 8:06 PM
In answer to the implied question about a fine & points if you've marginally exceeded a speed limit, yes I think it is fair. To avoid the fines, stick under the speed limit. I think the real question is to question whether the actual speed limit is relevant and challenge that with the road authority before you get caught.
21-03-2017 8:17 PM
How will you really know if you have marginally exceeded the speed limit as all the devices are just not that accurate. Are we saying that just to be safe don't exceed 25 in a 30?
The high paid will never get massive fines in marginal cases as they are the ones who can afford to shoot holes in the accuracy of the measuring devices.
21-03-2017 8:20 PM
Dashcams with GPS modules built in to show speed on the video would be useful, you just have to remember to hit the "save clip" button when you get flashed, video evidence is much better than technology that may or may not be calibrated accurately...
21-03-2017 10:20 PM
What isn't fair is the amount of flash adverts running in that page oldjim. Do you have any idea how much that just locked up my single core PC? lol
21-03-2017 10:37 PM - edited 21-03-2017 10:39 PM
Absolutely, much fairer than having a set amount regardless of income otherwise what's the point?
Paying a hundred quid out of a pension for example is a much harsher penalty for me than for say the George Osbornes of this world! As for clocking somebody doing 31 in a 30mph zone well that is clearly nonsense and something that could easily be challenged in court.
The higher the speed the higher the fine set against the higher the wage. Simples.
Don't limit the friends you haven't met with arguments you'll never have.
21-03-2017 11:06 PM
When I first read that I was wondering if it was an example of the "fake news" I keep hearing about.
I mean there are more important things that need doing regarding roads.
On another thread it's been about accidents, age, concentration.
Well I'm finding that a higher and higher percentage of my time when driving is on concentrating on the road surface just ahead of the car. To avoid ever increasing numbers of potholes. On some long sections of main road I virtually drive in the centre of the road.
And here we have a council blathering on about the minutia of road speed while Rome is burning.
21-03-2017 11:57 PM - edited 22-03-2017 12:52 AM
So true about those potholes, I'm on by third set of front suspension springs - the last one has only lasted two years so maybe they need the income from those fines to pay for road repairs.
No? Me neither.
22-03-2017 12:08 AM
The main road through our housing estate was in a really bad way with pot-holes causing motorists to drive slowly around the holes.
Then two things happened, the council resurfaced the entire road and introduced across the entire housing estate a 20mph zone.
Drivers now had a lovely smooth road to race down and the 20mph limit is generally ignored.
There is a junior school halfway along the road and I see most drivers will slow down when approaching the school during busy times.
Late in the evening it can become something of a drag strip at times.
Customer and Forum Moderator. Windows 10 Firefox 84.0.2 (64-bit)
22-03-2017 1:10 AM - edited 22-03-2017 1:13 AM
Sorry @Oldjim, but we seem to have fallen into a discussion here about potholes so here you go, four of them right in front of the house - and they wonder why we complain - as I have several times in writing and enclosing this photograph.
Dare to walk out as a car is passing in the rain and you'll get face full........ trust me
