Something for you kitchen Strat
pierre_pierre
2 REPLIES 2
Re: Something for you kitchen Strat
Beech!! guitar bodies are NOT made from Beech, which has all the tonal quality of a comb and paper. And anyway the Fender Broadcaster was a hollow body guitar, I think it should be Telecaster.
it's another of those repulsive bits-of-waste-wood-joined-together pieces of kitch.  after a while the bits begin to separate and guess what they harbour?
