Solvable Puzzle?
Fixes: 135
Solvable Puzzle?
Can the attached puzzle be done Undecided
Customer and Forum Moderator.
Fixes: 62
Re: Solvable Puzzle?
Given that the addition of three odd numbers can never give an even number I don't see how unless you use 2 x15 and leave the third one blank (hence zero)
Fixes: 34
It makes no reference to not using operators or limits to the numbers in the squares so:
[1+9] + [1+9] + [1+9]
(11-1)+(13-3)+(15-5)=30
No, I'm not that smart, I just googled the answer... Grin
Fixes: 135
Glad to be proved correct in that it cannot be done as a - character wasn't included in the list of available characters. Smiley
Well, it never said you can't use subtraction, got to think outside of the box, or boxes in this case... Grin
No, it says 'Fill in the boxes using...', the only things (characters) available (and therefore allowed by reasonable presumption) for use are the odd numbers 1 to 15 (plus a couple of brackets and some commas for the pedantic), the commas do open up a possibility if you're happy to accept alternative forms of numerical notation (namely the use, in some countries, of commas to denote decimals) so a possible legitimate answer (using ONLY the characters provided) would be 7,5 + 7,5 + 15 = 30
[/smug][/pedant][/smartass]
Call me 'w23'
Characters yes, nothing about mathematical symbols, which neither says you can or cannot use them, so, I assume can so that makes it solvable... Cool
When you eliminate the impossible, whatever remains, however improbable, must be the truth.
Mathematicians are nothing if not pedantic.  Lips are sealed
It says you can repeat the numbers, but not the brackets.
There are a few dozen answers if it wasn't limited to base 10
Quote from: twocvbloke
IMO '+' '-' etc. are characters (my PC/keyboard treats them exactly the same way as other characters).
If it never said you can't use subtraction then it also never said that you can't use anything else you wish and the whole 'puzzle' becomes meaningless.
Call me 'w23'
Fixes: 135
Typical theoretical mathematician.....change the question to suit the answer Wink Lips are sealed
Typo corrected Embarrassed
Typical pedant, it's suit, not suite.  Wink [/coat]
Call me 'w23'
Fixes: 135
Hope that "suits you sir"  Wink
Fixes: 19
no need to get shirty,..... he already has his /coat  Cheesy
