Soldering advice
Fixes: 9
Soldering advice
I Have done plenty of soldering in my time but recently needed to solder 2 small wires made of different material together, one  copper stranded and one metal stranded, they will be carrying a small current with at 12v DC  basically it's something I have fitted in my car.
My question, is there likely to be any problem in soldering wires of different metals together ?
Re: Soldering advice
I don't see why not, the solder itself will be a 3rd metal anyway.
When components are soldered on to a board the contact pins won't be made of the same metal as the conductive layer on the PCB, so that'd be 3 metals again.
F9 member since 4 Sep 1999
F9 ADSL customer since 27 Aug 2004
DLM manages your line the same way DRM manages your rights.
Look at all the pretty graphs! (now with uptime logging!)
TORPC
No there shouldnt be
However a flux solder may be required
Scribe
As long as it isn't aluminium it should be OK . Sounds like it might be tinned copper which is easier to solder that plain copper.
Fixes: 9
Thanks for the replies.
I Know some metals can react with other metals but thought I would ask to be on the safe side.
Smiley Smiley Smiley
Fixes: 21
If possible, just make sure you have a good "rubber sleeve" over the joint....
TORPC
Heat shrink tube may suffice
nanotm
just tin the ends of both bits of wire before you solder them together (I'd use a solder sleeve or a soldered crimp myself) to ensure you get a good joint
Fixes: 9
Quote from: TORPC
I Have some, but unfortunately could not use it as I was soldering into existing wires which I bared rather than cut through them.
