Sock it to me...
Sock it to me...
Aching leg from driving a manual gearbox car, 2am, can't sleep.
Pills & Potions appeared to have no effect at easing the pain.
Hot water bottle was too rigid to wrap around leg.
Now where do I get a microwaveable heat wrap at 2am ?
So onto the internet, and discovered it's actually very easy to make your own, especially when it's 7 hours until shops open.
Sock partially filled with about 500 grams of dry rice, cable tied closure, then 2 minutes in the microwave ...
Works a treat.
(I used Brown Rice, but White Rice would be OK  !)
I did carefully watch the microwave in case the sock & contents caught fire / exploded, no such problem.
I've now re-used the sock combo a few times, in fact using 1kg of rice, I now have two !
They also smell nice when warmed.
 And they work a treat at relieving the ache & pain. Instantaneous relief.
11 REPLIES 11
Pete11
Seasoned Pro
Fixes: 4
Re: Sock it to me...
A very handy tip, but I would have thought the cable tie would have melted being as they're made of plastic.
A float tip is pleasing in its appearance and even more pleasing in its disappearance.
Growing old is inevitable...But growing up is optional.
I did wonder, hence my watching, but the tie didn't even get warm, after two minutes.
They are specced to 85ºC. Presumably not affected by microwaves ?
I have a new friend !
I now have a Midnight Sock Buddy !
It is nice & comforting to carry it around, just takes the chill off.
And it lies across my leg, like a faithful pet dog, when I sit down at the computer....
Alex
Fixes: 12
Well @Anonymous that's an innoviate idea Smiley
Just wonder how often the rice will need changing before it doesn't smell so good?
HairyMcbiker
Fixes: 21
If you keep it inside a plastic bag (in the sock) then it should be fine. As that is basically what the head pads are.
billnotben
 I guess we all have different hardships to bear and struggle to overcome.
Rice is cheap enough to replace regularly, if needs be.
When you haven't driven a manual geared car, with clutch for a while, in an old sports car, you notice it !!
billnotben
Infinity wrote: an old sports car
 You can't leave it there. What old sports car?
I'd guess it would be something like a vintage supercharged Bentley.
Did they ever do a hybrid version of that.Smiley
Something like that !!
Alex
Fixes: 12
Yep, it's not like you're eating it, so you don't care as much Tongue
