So, who peed in the pool?
- General Chat
- So, who peed in the pool?
09-08-2016 10:50 PM - edited 09-08-2016 10:54 PM
Olympic pool turns a green colour
Looking more like water from the Amazon than regular pristine pool water, the diving continued regardless as the blue color slowly turned a dirty green.
The five-metre deep diving pool - which was a normal blue colour during the men's event last night - appeared to slowly turn greener as the competition went on.
Not sure why we get the American spelling of colour, though
Forum Moderator and Customer
Re: So, who peed in the pool?
09-08-2016 11:04 PM
Can't say I believe the algae explanation as the water still looks too transparent for that.
My money is on some joker just having a laugh.
09-08-2016 11:16 PM
I'd say it's the start of an algae bloom, left unchecked it will just become a big green pea (or is it pee?) soup that nobody would want to dive into, they best get the ol' chlorine out and turn up the filtration pumps...
10-08-2016 12:10 AM
1) Did someone have these for Dinner ?
or
2) Someone put some fluorescein in the Pool
10-08-2016 9:18 AM
Or the Russians trying to get their own back for all the booing they've been getting!!
Or even better, they're diluting their samples before testing.
10-08-2016 8:24 PM
10-08-2016 10:25 PM
The P is silent, as in swimming!
Don't limit the friends you haven't met with arguments you'll never have.
11-08-2016 12:19 PM
Must have worked for us as we bagged a gold last night
11-08-2016 12:33 PM
Apparently it has helped divers judge the distance to the water easier?
11-08-2016 1:34 PM
They've identified the problem as a lack of chlorine in the water and it is being treated.
When we have a chlorine problem at my club the water doesn't turn green and it only takes about 30 minutes to rectify.
11-08-2016 4:33 PM
Cave tracing dye https://www.amazon.co.uk/Bailey-3589-Drain-Tracing-Dye/dp/B0041SUDHW will produce results like the pool.
12-08-2016 8:34 AM
Apparently the American spelling of words such as color for colour rather than being a mutation, has more to do with being closer to the original English than our own version which is closer to French. Talking of which, the same is said to be true in part as regards to French Canadian.
12-08-2016 3:27 PM
On July 4, 1776, the 13 American Colonies declared their independence from Great Britain. Cultural independence followed the political.
In 1783 Noah Webster, the first American lexicographer, began reforming certain spellings and (like George Bernard Shaw a century later) advocated further changes.
French-derived spellings — like "honour," "catalogue," and "centre" — were Anglicized to honor, catalog, and center.
In words where the "s" sounded like "z" or the "c" like an "s," the letters followed the sound: realize, defense, and so forth.
12-08-2016 3:32 PM
Rio diving pool has now closed after the water turned a murky green
Apparently they planted the Grass early for the Tennis !!!!!
14-08-2016 12:19 PM
Metro:
Rio Olympics organisers have finally discovered the reason the diving and water polo pools turned from clear blue to a murky green.
The change in colour, has been a huge embarrassment for organisers and the failure to understand why it happened only made matters worse.
It turns out that hydrogen peroxide was poured into the pools the day of the opening ceremony, causing the drastic colour change.
‘On the day of the Opening Ceremonies of the Games, 80 litres of hydrogen peroxide was put in the water,’ explained venue manager Gustavo Nascimento.
‘This creates a reaction to the chlorine which neutralises the ability of the chlorine to kill organics.’
A Rio spokesperson said that conditions then exacerbated the issue: ‘[The discolouration] was because of heat and a lack of wind. We did all the chemical tests.’
Daily Mail:
Rio chiefs use industrial pumps to suck out the dive pool's murky green water and refill it to make it blue again
