So glad I downloaded that...
Fixes: 238
I put this in Chit Chat rather than Software as it's more for discussion than help.
Is there a piece of software (free or paid for) that you don't use often but sometimes just have to say 'I'm so glad I have that' as it suddenly becomes invaluable?
One such software for me is LockHunter as it unlocks most files that fail to move or delete. I needed it today but it must have been many months since the last time.
Forum Moderator and Customer
TORPC
Re: So glad I downloaded that...
For me it would most likely be XAMPP / PFPort Checker / NovaBench
Glenn
I was thinking of my programme Unlocker on my XP which does exactly the same as LockHunter....totally invaluable wee programme that saves the day every now and then.
Smiley
Fixes: 10
IrfanView - I often have to convert image types.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
Fixes: 238
I used to use Unlocker but when I moved to W7 in 2009 it wasn't compatible.
DVDShrink for me! Will shrink a DVD to fit on the easily available 4.7 gig discs!
Don't use it quite so much these days, but it's nice to know it's still there.  Smiley
Geoff,
York.
Fixes: 62
Me too and also DVD decrypter even though I don't use either of them now
I also use Infrarecorder as a CD and DVD writing utility but not very often now as I rarely need to
The one I do use all the time is FastStone Image Viewer for image resizing, removing meta data, cropping and minor adjustments as well as screen caps
Pro Photo Tools (MS) used to update the EXIF on Jpeg files with geopositioning information
Fixes: 9
Onone software, great for improving photographs easily and quickly.
PitchBlack
Quote from: Oldjim
DVD decrypter
+1
Fixes: 348
spinrite, not needed often but awesome and helped a lot.
Customer / Moderator / If it helped click the thumb / If it fixed it click 'This fixed my problem'
nanotm
years ago I burned a dvd full of xp related tools, one of them was the ability to boot into a windows recovery suite that bypassed all the passwords on the machine, worked a treat when hdd's failed for data retrieval (well for the ones that just had a bad boot sector)
several of them still work today under W7 but none of them work with W8....no doubt there will be an updated version made available in a few years (for free that is) I used to use magic dvd (and before that 321 studio's xcopy gold) before they were deemed illegal ......
Fixes: 12
UniformServer (apache, mysql, php)
PostImage windows app - screen cap tool with built in upload / hosting of images - great for forums
Win2VNC (allows you to use another machine with the same mouse /keyboard - as if it's a second monitor)
Notepad++
CutePDF printer
Flashget
WTF
+1 for Notepad++ - I like that so much I persuaded the two places I've worked to install it
AVG, Avast and Malwarebytes 'free' versions
7z
AndroidSync
I also have something I use to shrink podcast MP3s .. but I've forgotten the name
Fixes: 238
Quote from: WTF
Handbrake?
