Smart Televisions
- General Chat
- Smart Televisions
Smart Televisions
04-06-2017 1:52 PM - edited 04-06-2017 1:53 PM
As somebody who is new to smart TV maybe others can help here.
The Panasonic Viera I bought just over a week ago has been great so far and much easier than using those dangling dongles. This afternoon however when trying to watch BBC iPlayer for example it's telling me to connect to the internet but on the network settings I can see that it obviously is, so what's happening.
A quick check on the web tells me this has been an issue in the past with Panasonics and that in several cases it been because of their own server - at least that's the way I'm reading it. So is that the way these things work, Panasonic, Sony or whatever connect their televisions to their own server via my internet connection? I'm finding it hard to get my head around that one.
Any clues guys, am I going up the wrong path or what?
Compare yourself to who you were yesterday, not who somebody else is today
Re: Smart Televisions
04-06-2017 2:12 PM
these devices are just like any other device that connects to the internet, in that it connects to the internet directly and not via a third party proxy.
it could be that the iplayer app pre-installed needs authentication with a panasonic service first, but even that i would think was totally nonsense.
04-06-2017 2:20 PM
Well this was one link I looked at Chenks and as you can see a couple of replies talk about Panasonic network so......
I'll give it while and then start bothering Panasonic, or maybe my son-in-law who has had the same model for over a year.
04-06-2017 2:20 PM
I've had a Panasonic Viera for six and a half years and never met the issue you are describing. Have you tried changing the DNS to 8.8.8.8 and 8.8.4.4 ?
Forum Moderator and Customer
04-06-2017 2:23 PM
are there any sources other than "computing.net" and threads that are newer than 2015?
try avforums, i would use that as a more reliable source than computing.net to be honest.
04-06-2017 2:29 PM
Is today the first time you've used this device on line @Minivanman?
04-06-2017 2:42 PM
Been using it on-line for a week with no trouble @Anonymous and it's been great.
It's a puzzle to be sure.
04-06-2017 2:46 PM
I have a Samsung smart TV , Ocasionally it will say cant connect to server when it wants to Update , but its just the Samsung server maybe just too busy
04-06-2017 2:47 PM
Why should that work @Mav?
I'm not much of a new tech guy to be honest and that sounds complicated and as said to @Anonymous it's been working fine on-line all week.
Maybe I'm just panicking (had to save up for a while to buy it) so I guess I'll see if it corrects it'self somehow.
04-06-2017 2:48 PM
Well it's that server business that has me puzzled.
04-06-2017 2:49 PM
I seem to remember I had a few issues when using Plusnet's DNS that went away once I switched to Google's. But that was over six years ago so maybe I am remembering things wrong.
04-06-2017 2:52 PM
I'm thinking the same as @rongtw here @Minivanman in that it could be a hiccup on the Panasonic side of things. One thing I would suggest is that you see if there is anything to upgrade. I know the TV's new (to you) but it may have been in a warehouse for long enough.
04-06-2017 2:52 PM
that's not the same as what the OP is having troubles with though.
doing a system update would connect to a manufacturers server, but only for that.
it wouldn' connect to that for internet access.
04-06-2017 2:53 PM
are you using a WIFI connection with the TV?
if yes, then that would be my first port of call to check.
easy check is to test using ethernet and see if the problem goes away.
04-06-2017 2:54 PM
why would it be trying to connnect to anything on the panasonic side to connect to on-demand services?
that would suggest they are using a walled garden proxy type network, which they don't.
