Slushy Cards
Fixes: 19
Slushy Cards
Does anyone else think that Christmas Cards/Birthday Cards have "too slushy" writings inside them?  OR.... Do you "actually" talk to your wife, in the terms of endearment{?} expressions used in them?
I find it very difficult to find a card that says what I want ..... and a blank card, does not have the same "impact" on  `er indoors, when I try and write my own words inside.
Re: Slushy Cards
I have mine printed for me with a very simple salutation - Merry Christmas and a Happy New Year.  That covers all eventualities Wink
Fixes: 311
Re: Slushy Cards
family ones i use funky pigeon to get ones printed, it's more personal and usually cheaper than shop bought ones.
Customer / Moderator / If it helped click the thumb / If it fixed it click 'This fixed my problem'
Re: Slushy Cards
We cheat'; we've given each other the same cards for the last ten years or more (birthday and anniversary too) they are rather nice cards though.
Other family and friends get new cards (usually Heart Foundation charity)
