Slow Cooker vs Pressure Cooker ?
Fixes: 7
In conversation with a customer yesterday , some how got talking about the above, we current have slow cooker, which i think is brilliant for stews, but was told pressure cooker is much better and makes the meat taste better.
What are others view in this?, if true think i will making a purchase Smiley
Regards
Mike
Mike
Fixes: 21
Re: Slow Cooker vs Pressure Cooker ?
Depends on the meat used. In a slow cooker you can use tougher joints (cheaper ones) and the long slow cooking time gives a lovely stew.
In a pressure cooker you would need to use more expensive cuts.
I used to have a PC and used it for soups, a 1 hour simmer soup could be made in 20min. Sadly is is now deceased.  But I use my SC for stews and curries, the meat usually just falls apart.
Fixes: 384
They're not really interchangeable, each has it's own use.
For me meat has a bit of a flatter taste in a pressure cooker, so very much each to his (or her) own.
Pressure cooker will cook it quicker, I like to be able to leave the slow cooker unattended all day.
Customer / Moderator / If it helped click the thumb
My Broadband Ping - PN-Fibre
I'd have to disagree somewhat with Hairy McB, I find that a pressure cooker (because of the raised pressure I guess) tends to tenderise cheaper cuts of meat - it even makes Tesco stewing steak edible.
I sometimes use mine to 'pot roast' a brisket joint and it works very well.
Call me 'w23'
Fixes: 186
I had Sunday dinner at a relatives the other day and the beef joint had been cooked overnight in a slow-cooker and finished off in the oven.
The roast potatoes had been put in the juices in the slow-cooker after the joint and finished off in the oven.
All in all a very enjoyable dinner.
For a Technical Director, my son is a mean cook Smiley
Customer and Forum Moderator. Windows 10 Firefox 64.0 (64-bit)
I use a slow cooker mainly in the winter and find it excellent.  Put the ingredients in and then forget it until you're ready to eat.  Long time since I used a pressure cooker - may give it a try after reading this thread Smiley
I worry about the steam pressure in my PC.
Now Zen, but a +Net residue.
Fixes: 186
It doesn't seem to be a problem Smiley
Quote from: Hairy
I used to have a PC and used it for soups...
Would you use a PC for larger meals , and laptop if you just wanted a few bytes? Grin
(start punning guys)
Fixes: 250
Quote from: doris
No chance...
But I would use my SmartPhone if I just fancied a nibble Wink
Forum Moderator and Customer
Fixes: 186
Oh...the pressure's on now.........to resist.
The intel I have is my PC might blow a gasket
Too much? Try a tablet then....
Fixes: 21
Yes, indeed,..... they are excellent for making gravy or stock  Cheesy
Fixes: 250
My PC does a nice fried egg Cheesy
An no need to worry if it spills over as everything will turn out all white Wink
