Sleepwalk
Sleepwalk
For guitar instrumental fans, have a look at this You Tube listing.
There are a number of versions of the great hit of the late 50's by Santo and Johnny: Sleepwalk. The only chart hit played on a steel guitar.
But there are versions by Les Paul, Chet Atkins, Hank Marvin, Joe Satriani, Jeff Beck, The Shadows, Mark Knoffler and a few others. There are a number of other tunes on it as well , but you will need to keep pressing "show more" at the bottom of the lists.
1 REPLY
Fixes: 80
Re: Sleepwalk
I like Satriani's version https://www.youtube.com/watch?v=5c8nanTCPz0
Customer and Forum Moderator.
