Sleep
Fixes: 9
Sleep
I Thought as you got older you needed less sleep, I seem to need more and sleep like a log (without medication or alcohol)
How well do you sleep ?
Re: Sleep
By some standards not well. If I sleep for longer than a consecutive fours its a good nights sleep for me. As anybody who notes the times of the posts I make in chit chat will verify. My GP sees nothing wrong with this. On the very rare occasions I "sleep in" for more than eight hours I awake with a crashing headache feeling generally awful.
But I don't worry about it. Which is the worst thing you can do.
Re: Sleep
I am an insomniac and have been as long as I can remember.  I am lucky to get 4 continuous hours and always seem to wake around 4am and find it impossible to get back to sleep again.
I have spoken to my GP and when I get back from holiday I will be visiting a sleep clinic to see if there is anything that can be done for me. There are not very many proper sleep clinics around and I have been offered appointments at Cambridge, Oxford or the Royal London.  I will be contacting Cambridge. Although it is not the nearest it is a particularly good unit.
Fixes: 16
Re: Sleep
Quote from: artmo
If you`re going by train....... make sure the guard wakes you up when you arrive back home......... ! ! ! ! !! ! ! ! ...
Re: Sleep
I like it Shutter Wink Wink (appropriate smiley)
Steve
Seasoned Pro
Re: Sleep
Quote from: artmo
May I ask how much sleep you generally get per night? Is It worse than your 4 Hrs average? Also how were you diagnosed? As I am on sleeping pills but they don't work that great.
If life gives you lemons, make lemonade.
Fixes: 10
Re: Sleep
My sleeping pattern is so screwed up I've no idea whats normal anymore.
I used to think I was late hitting the sack at 2am.. then i did night work... now i'm out of work.. half the time i got to bed at 2 and am still awake at 5....
I'm utterly confused..
Steve
Seasoned Pro
Re: Sleep
That wont help depression sprite, I take a shed load of pills for depression and sleep, They knock me out fast but only for a couple hours, Took me years to get the doctors to listen to me about my sleep. Now that gets treated with depression because no sleep makes It a whole lot worse. I'm only 36.
Re: Sleep
It depends but I can normally get 2-3 hours sleep when I go to bed and then wake up.  I then can sleep again for a short period but by 4am I am awake and can't drop off again.  My insomnia was originally diagnosed by a professor at Kings College.
Sleeping tablets are not the answer as you will eventually get used to them and they lose their effect.  If I have had a particularly bad patch I will sometimes take a Sonata.  This capsule is widely used in the US and my GP is happy to get it for me.  It is a short acting capsule and can give you up to 4 hours of sleep.  It's very useful as it can be taken at say 2am and you can still get p at 6am and start the day off normally.
Steve
Seasoned Pro
Re: Sleep
@Artmo, Tell me about It, My sleeping pills have just been Increased to double dosage, I may look Into Sonata, Is It herbal?
nadger
Re: Sleep
Overall I get a reasonable amount of sleep but it's probably in 90 minute spells. I normally wake up and have a drink of Robinsons Fruit & Barley then go back to sleep. I also have an hours nap most afternoons.
I'm not an early riser these days - probably about 08.30 most mornings.
Re: Sleep
@Steve M No Sonata isn't herbal.  It's pharmaceutical name is Zaleplon.
Sonata
Steve
Seasoned Pro
Re: Sleep
@Artmo thanks, If you have any of these conditions, you may need a dose adjustment or special tests to safely take zaleplon
liver disease;
   sleep apnea (breathing stops while you are asleep);
   lung disease such as asthma, bronchitis, emphysema, or chronic obstructive pulmonary disease (COPD);
   a history of depression, mental illness, or suicidal thoughts; or
   a history of drug or alcohol addiction.
Fixes: 16
Re: Sleep
Have either of you tried "horlicks"?
Steve
Seasoned Pro
Re: Sleep
Ive tried many things but never tried horlicks, I used to sleep like a log, was a deep sleeper, All that changed when things went pear shaped In my life, However I have been sleeping In a single bed for the last 7 years and I'm 6 ft 2 in.I am In the middle of moving home to a much larger home, Where there Is space for a double bed, I also have ordered a double divan with memory foam 10 Inch deep mattress. Hopefully Ive reached a turning point In life and sleep may Improve Itself.
