Sky router with plusnet
tomxlisa
Does anyone know how to get the sagemcom 2504n router to work with plusnet, i have looked on the internet but don't seem to be able to find anything on it?.
Fixes: 45
Re: Sky router with plusnet
The router is 'locked' to Sky. You will probably need to reflash it with stanadrd firmware. This link http://www.hotukdeals.com/misc/flash-a-sky-sagem-router-161928 might help.
scream
There's always the Kitz site too, I find them helpful anyway Smiley
http://www.kitz.co.uk/routers/skyDG934.htm
This links you to re flashing it to use Netgear software, always good as Netgears are generally commonly known and easy to use too.
