Sky HD
Sky HD
I just wondered if the sky hd channels have better picture than the free channels.
6 REPLIES 6
Fixes: 5
Re: Sky HD
If they're in HD, I'd imagine they are.
I think freeview channels that aren't HD are 480p whereas HD channels are 720p - I think.
Champion
Fixes: 12
Re: Sky HD
SD channels are 576i
HD channels are 1080i on sat/cable and via DTT they dynamically switch between 1080i/1080p
The bitrates vary and this will have an impact on PQ
Though i think you need to define what you mean by  Sky HD channels and Free Channels...
Re: Sky HD
The other variance is the amount of compression some channels apply.  And the +1 channels are even worse for it.
Re: Sky HD
To define what I meant there are free HD channels such as BBC and ITV and a few others
Fixes: 12
Re: Sky HD
that's still somewhat ambiguous.
do you mean, for example, is BBC 1 HD better on the sky platform than on the freeview platform?
Re: Sky HD
Digital Spy is the place to ask this type of question!
http://www.digitalspy.co.uk
Geoff,
York.
