Sign of the times
johpal
Sign of the times
My employer (funded by the tax payer, of which I am also one) has a notice fixed to paper hand towel dispensers:
"Why take two ... if one will do?"
Today, I found an added scrawl to the unit in my department:
"If its free ... take three!"
Fixes: 51
Re: Sign of the times
That's absolutely correct. If something is perceived to be free to the user it's often wasted.
I saw this in action with my electricity when my kids were at home.
I see it in Mc Donalds where people will take a handful of tissues and only use one, throwing the rest away.
Customer and Forum Moderator.
Fixes: 13
Quote from: Strat
Never seen that happen in McDonalds..    Undecided  ..................................... but there again.............................. don`t go in McDonalds..  Cheesy.....................
I knew I was right to boycott it as soon as it appeared over here ! ! !  Grin
Fixes: 51
@Shutter even at your age it's still ok to get out and experience new things Cheesy
...even if it's just a coffee and their free WiFi Smiley
Sorry they don't have an alcohol license ......yet
Fixes: 9
There must be a knack  to using these paper towel dispensers... it's not uncommon to try and get one out and you end up with several.
Even worse are those toilet tissue dispensers but let's not go there...
jmd
where then?
Fixes: 51
Mc Donalds. Wink
Quote from: Strat
You've got a good point there. I wonder how people's attitudes would change if they were charged 1p for anything that was previously free? 1p would be such a small amount that it wouldn't have any significant effect on people's finances, but I bet the psychological barrier would make a big difference in cases such as this.
Fixes: 13
Carrier bags, are "free" in Morrisons...  Cheesy  .. but you have to pay for them 3p (for the cheap one) in Lidl.... Cry
I alway carry a couple of Morrisions carrier bags in my pocket, when I go to Lidls.... !  Wink
(yup I was born in York! ) Roll eyes
In M&S carrier bags are 5p each.  Sad
Fixes: 51
I have two Tesco re-usable woven material bags which cost me about 50p each and look as though they will last for years.
Unless I forget to put them in the boot I don't use plastic bags any more.
jmd
I re-use the plastic bags I get free in Tesco/Sainsburys to put my rubbish in.................... [cheaper than buying bags specially for pedal bin!
I also re-use bags when I go to Aldi as they charge 5p
You have to save a little...........................
Fixes: 13
Quote from: jmdlp
and as Tesco keep remininding us
"Every little helps"  !  Cheesy
On the subject of plastic grocery bags, I seem to recall that Tesco give you clubcard points for every bag (of any type) that you reuse instead of taking a new one – so that's a small incentive in itself to be more frugal with your plastic bag consumption.
Same at Sainsbury.  One point per bag if you don't use a new one.
