Shower hose joiner
Fixes: 13
Shower hose joiner
Have been looking around, screwfix, b&q, ebay... to see if there is such a thing...
I want to join two shower hoses together to make an extra long one.... the longest I have seen is 1.75 mtrs  but I would like a minimum of 2.3 mtrs, so joining two1.5 together would give ample lenghth..
Has anyone come across such and item... if so... please can you point me in the right direction >>> ? ?
Re: Shower hose joiner
1.75m, pah! http://www.ebay.co.uk/itm/like/251227250860?  Cheesy
Loads around 3m long.  Wink
You'll want a large internal diameter one if flow/pressure is a problem.
Shower hose connectors are (almost always) 1/2" BSP (parallel thread), search 1/2" BSP nipple (beware they come with tapered as well as parallel threads) and you should find something suitable (they should be available in brass, stainless steel and plastic to suit different requirements) - if HPSauce's suggestion doesn't suit.
Call me 'w23'
VileReynard
Seasoned Pro
Fixes: 9
I have to ask...
Why is that called a nipple?
Doesn't look much like one.  Grin
It was named by engineers, they (we) find such things amusing.
Nipples
Nuts
Flange
it's a laugh a minute.
Call me 'w23'
Don't forget "ballcock"... Grin
Fixes: 13
Once again.... this forum has come up with the goods... I would never have thought of looking for " coupler "    Shocked    ... or "nipple"..  Embarrassed  with respect to a "connector"...  Huh
Anyway... as I already have two 1.5 mtr hoses... I`ll go for 2cvbloke`s answer for 99p...
Thanks guys.... Brill !  Cheesy
rongtw
Fixes: 12
us older engineers had a thing about names , hence male & female threads  Wink
-Flange ,,,-Gusset -,,,,,Penetration ,,,,-Lubrication failure,,, -Ring Expander ,,,,-Shaft (especially when combined with Thrust),,,, -Orifice gauge .,, Lay shaft ,,
ooooops have to be careful not to be told off by the Mods  Wink
Fixes: 51
Quote from: vilefoxdemonofdoom
Because what connects to it goes around the outside....like a baby's mouth.
Customer and Forum Moderator.
VileReynard
Seasoned Pro
Fixes: 9
Not like a grease nipple, then. Cheesy
rongtw
Fixes: 12
have you ever felt the suction on them grease guns  Smiley
