Shortcrust Pastry
- General Chat
- Shortcrust Pastry
Shortcrust Pastry
25-10-2016 11:51 PM
At the weekend I made a few apple pies using apples from the garden. They turned out good except the pastry isn't particularly crumbly and after a couple of days they do tend to seem a bit tougher and nothing like my old grandmother used to make
Sadly my mum is no longer able to recall how to make pastry so I have been looking at 't'internet then decided perhaps people here have tried and tested recipes that I could attempt.
Currently I use:
½ lb plain flour
Pinch of salt and half teaspoon of sugar for sweet pies
4oz butter
2oz lard
Cold water to mix
I rub the butter and lard into the flour, salt and sugar mixture till it resembles breadcrumbs then make a well and some of the water and mix with a fork. When it becomes 'sticky' I then finish mixing with my hands. I then put it in the fridge for 15 minutes before rolling.
So any ideas for a different/better recipe would be greatly appreciated.
Forum Moderator and Customer
Re: Shortcrust Pastry
26-10-2016 5:50 AM
I use very little pastry in cooking and have to admit I cheat and buy the ready made pastry from the supermarket.
26-10-2016 8:57 AM
Quite agree, even TV chefs admit to using ready-made (particularly filo and puff).
I have made pastry, not always successfully. SWMBO used to make delicious shortcrust pastry and swore by adding an egg.
26-10-2016 9:25 AM
My MiL used to make beautiful pastry and never weighed any thing.
Mine always turns out tasty but a bit tough. Apparently I handle it and roll it too much.
27-10-2016 11:01 AM
Use very little water - just enough to bind it (much less than you think as the fat encapsulates almost all the loose gluten in the flour. It's the gluten that gets sticky and bind it together).
A cheat is to replace 10% of the flour with rice flour. It will make no difference to the taste but as it had no gluten it breaks up the long chains of gluten (it is these that make it 'tough').
Pastry when mixed should 'snap' not fold when you try to fold it in half.
On the gluten front - if you check the flour label it will have a figure for protein content. The lower the better for shortcrust pastry, ideally under 9%. Conversely, for bread this figure needs to be higher, ideally 13%+. Wholemeal bread will not rise as much as white bread because it includes the ground husk, which as it had no gluten in it brings the overall gluten content down. Too produce Voluminous wholemeal loaf you can add dried gluten.
Here endeth the lesson....
27-10-2016 11:58 AM
i love flaky pastry the wife makes great chicken,bacon,leek pie with flaky pastry.
27-10-2016 3:16 PM
Thanks for the replies.
Will be making more (meat) pies next week so look forward to doing it differently.
29-10-2016 7:55 AM
Make sure you don't use a hard flour such as a bread flour. Use a general purpose cake flour.
If you are making pastry for savoury food use lard as the fat, for sweeter pastry use butter. I use 50% fat to flour by weight. Handle the mix as little as possible and keep it cool. Use just your fingers in contact with the fat and flour when blending to make the crumb. You should be trying to avoid melting the fat as you mix.
I tend to use iced water when mixing the crumb. Avoid kneading the dough.
05-11-2016 8:21 PM
I found the following recipe and using the hints and tips above I made an apple pie plus several chicken and mushroom pies and the pastry was exquisite; very crumbly and tasty, just how I like it
Also made a batch of apple crumbles so I am covered for the next few days. Still got lots more apples in the garden to harvest. Not actually sure what type they are so may take a photo and perhaps someone can help?
