Shocking?
Shocking?
I've had my Pentax *ist DL2 camera for a few years now, So this morning I thought I'd take a look at the instruction manual!! (I wonder how many others actually take the time to read manuals thoroughly, as somebody who was involved in writing them once upon a time you'd think I would know better wouldn't you?)
However, I was intrigued by a heading right on the first page..."Warning" "Do not disassemble or modify the camera. High Voltage areas are present inside the camera, with the risk of electric shock"
I wonder, how much danger there actually is of being electrocuted by a camera that is running off 4 x AA batteries?
Denzil
Re: Shocking?
I would guess there is a big capacitor in there somewhere to power the flash. The small DC voltage from the batteries can be multiplied up quite a lot with an inverter. I doubt it would do you much damage, though.
198kHz
Aspiring Champion
Fixes: 11
Re: Shocking?
While unlikely to be fatal, there certainly is a significant risk of shock from the flash circuitry of a camera. The flash tube is fired by discharging a capacitor which is charged up to several hundred volts.
http://camerarepair.blogspot.com/2007/11/important-warning-camera-flash.html
Remember you are unique - just like everyone else
Re: Shocking?
It is all symptomatic of the Health & Safety culture we now "enjoy". There are endless examples of such overkill (sorry!).
I also have an antique Pentax 430RS which gives excellent service despite a handbook more like Encyclopedia Brittanica. I have read most of it,,, ,but am now of a age that about 10% is absorbed. It does have a "proper" viewfinder which is invaluable in bright sunlight, (which we have right now), and which defeats most with newer hardware and only a screen to look at!.
Re: Shocking?
Quote from: colintivy
Quite agree, I much prefer a viewfinder for composition. As it happens the Pentax I have doesn't have screen preview/composition (in common with most DSLR's I think, only for post taking review, the length of time that shows can be varied. The screen in screen-only type cameras is the major source of battery drain.
Some of the later screen only types have a rotating/angling mounting so the screen can be moved out of direct sunlight I believe, which I guess if you must have this type of camera is a good idea.
@ Denzil and Foresee, thank you for that info, I'll remember to be careful should I ever facny delving inside my camera.
itsme
Re: Shocking?
I believe the warning is appropriate and have probably been there before the HS culture that we now live in. I believe the danger is more from the involuntary reaction to the shock than to electrocution. I speak as someone that have on several occasions had several hundred volts shocks from a small Geiger tube fitted in a personal radiation monitor, it does make one jump a bit  Grin
Re: Shocking?
I hope you didn't snap when you read the warning Petlew Wink
Re: Shocking?
Again quite right itsme, When I was a service engineer for Hoover we were issued with a Metrome meter, which could deliver a nasty shock if you were "silly" enough to hold the leads when it was discharged, indeed some spiteful engineers would set up their unsuspecting colleagues to receive such a shock. However I think you are quite right, it is more the surprise than the voltage as there is very little amperage in the circuit. We had two types; one was a wind-up the other was switch thyristor operated.
Re: Shocking?
@ artmo, no, I saw it all in black and white...
Re: Shocking?
And thinking negative thoughts...
Re: Shocking?
See what develops next Wink
Re: Shocking?
Ok, let's look on the positive side of things...
Re: Shocking?
Bet Shutter would like this thread Roll eyes Roll eyes
Re: Shocking?
Yes, his names certainly in the frame for this one...
Fixes: 247
Re: Shocking?
Well perhaps he shouldn't have been so snap happy....... Wink ;P
Customer / Moderator / If it helped click the thumb / If it fixed it click 'This fixed my problem'
