Secure disposal of CD-RWs
maranello
Whilst this is a serious request for advice, the potential for frivolous debate and comment is considered so great that I think this is probably the best place to post.
What I would like to know is how people dispose of CD-RW (or any other format) disks containing personal information. I'm interested in terms of both identity theft and environmental issues.
Suggestions using any form of motorised or gas powered kitchen equipment are likely to be vetoed by SWMBO.
My other car isn't a Ferrari
Fixes: 355
Re: Secure disposal of CD-RWs
You can shredders that will shred CD / DVD's. though taking a lighter to them and melting bits or snapping them would make it pretty unreadable.
Customer / Moderator / If it helped click the thumb / If it fixed it click 'This fixed my problem'
Fixes: 62
Equipment
Safety glasses
Heavy duty leather gloves
Large bucket
Take CD in hands inside bucket and bend until it breaks
Fixes: 10
Bang the edge of the disk on a hard surface a number of times. All the bits fall off which renders it unreadable.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
Fixes: 355
you could use a hole punch and make pretty patterns and sell them at craft fairs as designer Wink
Fixes: 238
Quote from: Oldjim
Equipment
Safety glasses
Large bucket
An easier solution is to place in n A5 envelope and bend till it breaks. Less hassle and you don't need safety glasses Cool
Forum Moderator and Customer
Microwave.  Cool
Fixes: 10
Blender
Fixes: 12
Quote from: dvorak
Thats what I have although it only cuts the disc in 3 places its probably enough to make the data unreadable I would hope. If its really serious data then scratching the top of the CD (where the silver stuff is) with a sharp point before shredding will also do the job.
Quote from: jelv
Blender
Very good! (For anyone else, the action starts at 1:10 )
Infinity
Seasoned Pro
I use a £5 manual shredder that also cuts CD/DVD into 3 pieces.
After shredding a few, I put the 3 pieces into separate plastic bags in bins, and dispose of different weeks, or into different public bins.
Shredder is of this type...
(For paper I use a cross cut shredder, with added water into plastic bag, to smudge ink / make paper soggy)
RPMozley
Fixes: 5
The first step with a CD-RW (or DVD-/+RW) is to fully erase the rewritable disc in a drive. Then after that any of the options above to be completely secure.
That's RPM to you!!
Infinity
Seasoned Pro
Personally I never put anything personal from my computer onto rewritable discs, CD or DVD, I reckon they can be un-erased, if re-used.
Stolen or mislaid.
Matters less once shredded of course.
With recordable DVD's costing around 10p each, and not a single failure, I use these as backups.
Plus other means of backup .
And all my personal information is password protected anyway. Excel, Word, PDF's, Photo's Folders etc.
DVD±RW's I only use in my TV DVD Recorders.
Fixes: 12
Quote from: PlusComUK
Sheesh, I dread to think what you're hiding  Shocked
Infinity
Seasoned Pro
My fortune !
It's actually very easy, once you get into the habit.
I did try the bendy CD process once, splinters everywhere !
I do wonder if you sellotape the 3 pieces together off the same disc, would it be readable in a tray mounted loader, anyone try it ?
Or what you get with 3 portions of different discs ?
You could do what one of my neighbours has done; and attached them to his bicycle wheels so they make pretty patterns of rainbow hues as the wheels turn. Wouldn't think they're much use for anything after a few hours of that.
