Second hand car tyres
Minivanman
Aspiring Legend
I must get out more, I never realised you could still buy part worn tyres, and 4.5 mullion sold in the UK every year! Blimey, last time I even thought about doing such a daft thing must have be about forty years ago.
Time to make it illegal before we make ourselves inadvertently illegal I'd say.
http://www.bbc.co.uk/news/uk-38691767
Don't limit the friends you haven't met with arguments you'll never have.
24 REPLIES 24
twocvbloke
Re: Second hand car tyres
They're perfectly okay so long as they're approved and properly checked over, rather than the cheaper, "under the table" types from dubious back-street garages where they're taken off scrappers and re-sold as-is without so much as a look over for defects... Smiley
Minivanman
Aspiring Legend
Like second hand food you mean? Smiley
twocvbloke
No, that's just being silly... Roll_eyes
Next you'll be saying second hand cars should be illegal, cos there are cars on the road today that make dodgy tyres look like they're brand new... Crazy
gleneagles
Fixes: 16
What's your life worth ?
A front wheel blowout at 70 mph  could well end up fatal.
Sure new tyres can also blowout but the chances are less, I would rather know the history of my tyres from new despite assurances from any sellers of second hand tyres that they have been fully checked and tested.
Never try to save money on tyres or brake parts.
I could well be wrong but I am sticking to that view.
We are born into history and history is born into us.
twocvbloke
At the moment? About £3.47... Funny
Minivanman
Aspiring Legend
Totally agree @gleneagles, it would not enter my head these days to buy second hand tyres no matter how well they might have been checked. It's just not worth it.
If you cannot afford new tyres when they are needed, then you should not be on the road. Simples really.
shutter
Fixes: 47
@twocvbloke   THAT much  ? ? ?   Crikey me,..... you do have a high opinion of yourself ! ! ! ! ! ...  Grin
twocvbloke
That's not accounting for debt of course... Crazy
HairyMcbiker
Fixes: 21
2nd hand tyres are fine, went through dozens when I used to do 30K a year, £50 a pair fitted vs £150 for new ones which would be replaced in a year any way. Although I did have one that was a puncture magnet, after the 2nd repair, I bought a new one as it was cheaper.
The ONLY blow out I have ever had was on a NEW tyre. It had only been on for a few weeks, hole in the side wall. Eventually got a refund from ATS for it.
billnotben
Recycling is good but not for tyres? That makes no sense.
Why throw away perfectly good tyres.
My brother does 20000 plus miles a year and always buys 2nd hand. Never had a problem.
Imagine the rise in the price of goods if haulage companies were forced to buy new instead of retreads.
rongtw
Fixes: 12
100yds from my house is a tyre garage, new and part worn , i have complained to council several times over the amount of old tyres they stack up outside , fire hazzard !!.
Apart from that their bigest customers are local Taxi firms 😞
twocvbloke
Set fire to it and call the council to say "See? I told you it was a fire hazard!"... Funny
Mav
Fixes: 431
Is there a difference between retreads and part used tyres?
Forum Moderator and Customer
quelquod
Yes indeed.
A part-used tyre is exactly what the name says it is. It's been used before and no one has done any examination (apart from maybe a quick visual check) to see whether it's still OK. Often they come from accident write-offs, sometimes from people swapping tyres early etc. You pays your money ...
A retread is a professionally produced tyre to the standard of a new tyre. It has a new tread pattern vulcanised to the old tyre base and uses the original tyre sidewall structure etc. The tyre itself is no less safe than a new one, though the performance of the tread regarding grip, wet-handling, noise etc. will (almost certainly) be poorer.
It's worth noting that all or virtually all hauliers and bus companies use retreads and these heavy tyres are designed from day 1 to have multiple retreading.
Democracy - 3 wolves and a lamb voting about what to have for lunch!
