SatNav question
Fixes: 170
SatNav question
Thinking of getting one of these for SWMBO.
She's not very good at directions at all or getting postcodes.
If she was to enter something like Tesco, Canterbury or Argos, Westwood would it be able to get a route or would she at least need a road name?
Forum Moderator and Customer
Re: SatNav question
Have one of these http://www.amazon.co.uk/TomTom-GO-LIVE-820-Countries/dp/B0056G467Q
Slightly more expensive, but with the advantage of live traffic reports. Constant stream of updates. Some sellers (I got it when I bought mine) offer free lifetime map updates.
Recommended.
Fixes: 10
Re: SatNav question
You haven't actually answered the question:
Quote from: Mav
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
Fixes: 170
Re: SatNav question
Above my budget, sadly.
The one I linked to does have lifetime maps and Halfords are offering an extra 10% off everything between noon and 14:00 today so as we were thinking of getting one anyway may as well take advantage of the extra discount.
Fixes: 4
Re: SatNav question
I have a tomtom go 1000, great bit of kit, the battery died after just 12 months though.
you can tell this the destination if you like Smiley speak clearly where you wish to go, however i would advise you check just to make sure it didn't think you said moscow instead
Re: SatNav question
Ooop's sorry I was distracted.
You can't as far as I know actually input say Tesco, but you have POI's (points of interest) which will include a listing of local supermarkets, from there you can select it, you can then save it as a Favourite for future use.
Fixes: 170
Re: SatNav question
Thanks for that.
We'll experiment once we pick it up tomorrow.
I think SWMBO will just have to learn how to obtain post codes Wink
WTF
Re: SatNav question
Doesn't her phone have Google Maps?
That works fine for me.  She would need a plan that included some mobile data, of course.
Re: SatNav question
Smartphone would be my choice.
Fixes: 170
Re: SatNav question
She's not exactly tech savvy with regard to her Galaxy S3.
I think getting lost a few times when out on her own will encourage her to learn more Cheesy
I've already suggested she leave a few days' meals ready for when she does start going out on her own Wink
Fixes: 60
Re: SatNav question
I have Google Maps on my S3 and if I put in Tesco is shows me a list of nearby stores and I just pick one.
Customer and Forum Moderator.
pwatson
Re: SatNav question
Also may be worth trying Tom Tom Places (as it's free) - Looks to be just what you're after?
http://www.tomtom.com/en_gb/products/your-drive/smartphone-navigation/android/tomtom-places-app-andr...
I haven't tried it, but I do use the full Tom Tom satnav app on my android phone and have no desire to go back to a separate unit.
Fixes: 170
Re: SatNav question
Looks useful but, sadly, not compatitple with her S3 or my S4 mini Sad
Fixes: 46
Re: SatNav question
Most of the SATNav's will store previous destinations. Just put all the frequent ones in initially and then she can access those from memory.
Fixes: 170
Re: SatNav question
Good advice, thanks.
The irony of is it SWMBO wants to go out now to get the SatNav but needs it to go out on her own without getting lost Cheesy
We may go together later.
