SKY TV offered me a really cheap deal on a satellite dish. SKY+HD box is extra.
Infinity
Seasoned Pro
Fixes: 100
Re: SKY TV offered me a really cheap deal on a satellite dish. SKY+HD box is extra.
I can see the problem....the LNB isn't skewed correctly.
Customer and Forum Moderator.
And aligned to pick up the signal from the outdoor privy.
