{SEMI Solved} FF26 & Facebook mouse issues
Fixes: 21
Is anybody else having the same problem as me with fb & ff 26?
In every other page the scrolling is by wheel or cursor. On FF moving the mouse scroll the screen continuously.
EDIT: Looks like it was a corrupt restore removing FB and restarting FF fixed it.
EDIT 2: After a restart same problem is back. Remove FB and it is fine, wit FB in the window then the mouse misbehaves  Crazy
nanotm
Re: FF26 & Facebook mouse issues
is it a preference setting with the mouse wheel being clicked ?
normally when things like that happen to me its because I inadvertently pushed the mouse wheel down when swapping between open windows but re-pressing the mouse wheel fixes it
Fixes: 21
I have powered the pc off since it first appeared (with the update of FF yesterday)
It only affects FB. I have 20 tabs open (across 2 desktops) but FB is the only tab that it does it in.
EDIT:
It seems to be ONLY affecting the 2nd window. I can't click or scroll on it at all. It was only FB but now is all the tabs there. This window is fine!
EDIT 2:
OK. with FB removed and FF restarted all the windows work as normal. So def a FB/FF issue.
EDIT 3:
FB removed. New window (3rd) with Google & FB in it, Everything is fine.
Very strange, I wonder if it was a corrupt restore?
