Router
- General Chat
- Router
Router
20-11-2016 2:44 PM
Hi all, I have been with Plusnet for about 12 years although "ashamedly" I'm new to the Plusnet Community.
I have just changed my package to Fibre Broadand, Received my new Plusnet hub one router yesterday, so all set up now; thankfully without any problems. But I am at a loss of what to do with my old router, can it be used? do I recycle? Do I send it back to Plusnet? OR??? I would appreciate any suggestions. Many thanks. briggsby.
Re: Router
20-11-2016 2:47 PM
Sell it on Ebay... ! always someone wants a cheap router... to mess around with, or to replace a duff one..
Re: Router
20-11-2016 3:25 PM
Re: Router
20-11-2016 3:49 PM
You could use it to extend Wifi around your home.
Re: Router
21-11-2016 4:08 PM
Thank you all for you suggestions. all taken on-board, I have decided to send it to a charity shop, hopefully will find some one in need. Thanks again.
Re: Router
21-11-2016 4:14 PM
@briggsby That's a nice gesture. For what you'd get for it on ebay I don't think it would have been worth the trouble.
Re: Router
21-11-2016 4:19 PM
Re: Router
21-11-2016 5:34 PM - edited 21-11-2016 5:36 PM
...and ask for it to be deregistered from your account. If someone uses it on another PlusNet connection it will automatically configure with your account details.
edit: just noticed it is 12 years old, probably way before auto configuration so its not likely a problem
