Roaming Charges
petlew
Roaming Charges
I’m now holidaying with my family in New Zealand (where it’s cool and raining!!), I am wondering if I use this iPhone on my son-in-laws WiFi for purely internet connections, text, WhatsApp, browser do I incur roaming charges?, or only call charges if I use it as a phone.
The other option, I brought with me an old iPhone made sim free (same service provider as current phone) would it be better to to use a NZ sim in that instead?
2 REPLIES 2
Fixes: 1,207
Re: Roaming Charges
you only incur charges if you use the mobile data - if you're in roaming mode and attach to wifi you shouldn't incur any roaming charges.
Are you on PN for mobile?
Mustrum
Fixes: 56
Re: Roaming Charges
Top tip, switch roaming to off on your UK phone, get a local PAYG sim with as much data that you think you will need and put that in your spare phone. Set it up as a WiFi hotspot, connect your UK phone to that when you don't have access to any free WiFi.
Worked for me on my last trip to Aus.
