Right to Repair
- General Chat
- Right to Repair
Right to Repair
01-10-2019 1:31 PM
Interested to read this earlier about the 'right to repair' as I'm sure many of us here have been annoyed at not being able to fix something because of access or not being able to get to the spares needed because your washing machine is 'out of date'.
Built in obsolescence of course, but now some good news that it might all actually change and no, we don't have to be a member of the EU to do so.
Biggest bugbear, not having the right shaped screwdriver bit.
Example, replacing the rear stop light on my Fiesta which needed one of those star shaped bits to get the cover off.
Blimey, as if was not bad enough when they went over to those phillips/pozi drive screws!
Don't limit the friends you haven't met with arguments you'll never have.
Re: Right to Repair
01-10-2019 1:57 PM
Very often it's not the non availabilty of spares but the cost, especially if a 'professional' has to attend and fix things. It's very often cheaper to scrap and start again.
If.you go on to Screwfix you will find that for very little money you can get every screwdriver bit shape you will ever need. Buy a set and you will be set up for life.
Re: Right to Repair
01-10-2019 1:59 PM
My Skoda uses those star socket screws.... for the number plate light...got my tame mechanic to remove them and replace them with philips/pozidrive self tappers ... now I can change them when they blow, instead of a day in the workshop. ! ! ..
Re: Right to Repair
01-10-2019 1:59 PM
When a Phillips Is Not a Phillips!
Re: Right to Repair
01-10-2019 2:01 PM
You could set yourself up as a "Repairman" ..... !
Re: Right to Repair
01-10-2019 2:04 PM
I think I'd have stuck with the original screws as you're less likely to cause damage to the heads caused by the driver slipping.
Re: Right to Repair
01-10-2019 2:04 PM - edited 01-10-2019 2:05 PM
Set myself up? Many friends and relatives already see me in that role!
Re: Right to Repair
01-10-2019 2:10 PM - edited 01-10-2019 2:11 PM
We are talking about Torx fixings. I have a set and used one to dissemble a dead hard drive yesterday evening.
The set has only been used about 4 times but I'm a bit of a tool addict.
Customer and Forum Moderator. Windows 10 Firefox 84.0.2 (64-bit)
Re: Right to Repair
01-10-2019 2:18 PM
On seeing the link @RobPN posted above brought to mind the time I went fix a Bang and Olufsen TV for a customer who droned on and on telling me about the cost and the superior quality of it. So being a git I took great pleasure in bursting his bubble when I told him and showed him it was nothing more than a re-badged Philips.
Re: Right to Repair
01-10-2019 2:19 PM
I appreciate the difference @RobPN , unfortunately my screwdrivers do not which is why I and I suspect many others tend to lump them together. I now have a choice of three types of screwdrivers in my toolbox and never ever do I get the right one first. Perhaps they should be colour coded?
Re: Right to Repair
01-10-2019 2:22 PM - edited 01-10-2019 2:23 PM
@Anonymous
Not unlike car engines then.
Re: Right to Repair
01-10-2019 2:23 PM
Re: Right to Repair
01-10-2019 2:25 PM
@Minivanman wrote:
I appreciate the difference @RobPN , ...
No malice intended, I was just pointing out what a minefield it can be.
Re: Right to Repair
01-10-2019 2:25 PM - edited 01-10-2019 2:27 PM
The one missing off that list that catches people out is JIS.
Japanese Industrial Standard that is.
It's included in the list here.
https://en.wikipedia.org/wiki/List_of_screw_drives
It looks like a Phillips, but it ain't one. And if the screw is tight the wrong screwdriver will strip the head out.
Found on Japanese kit. Cameras, lenses, motorbikes, probably cars and lots of stuff.
But good news about stuff being more fixable. Of course if they wanted to most stuff could be made like a normal PC, and the parts could more or less "plug in" and use standard screws.
I'm not holding my breath. . .
Just to add, that someone once said to me "I wish I could mend stuff like you can"
And I said back "And I wish I could afford to pay somebody else to mend stuff"
Re: Right to Repair
01-10-2019 2:33 PM
You must have missed it, it's listed at point 10 of the list I linked.
